On a Stream Deck XL, the bottoms on the bottom row are usually easier to reach than the top.
So I wonder if it would be helpful to have an option so the icons automatically flow from the bottom.
That way you can set the Display Order to 0 for your most important buttons, to 1 for less important, and so on.
P.S. The Stream Deck support is great. I was close to selling mine before, but now it's perfect.
