Can someone please explain In Focused Window and/or Fixed On Screen triggers? Specifically in the Position on Screen settings for a floating menu. [Position Retrieved From Dynamic Variable or Named Trigger (In Focused Window] | [Position Retrieved From Dynamic Variable or Named Trigger (Fixed On Screen)]. I’m new to variables not just in BTT but also Siri Shortcuts, and shortcut tools like Toolbox Pro.[1] I've figured out what 'global variables' do and I know why a persistent variable would be used, but that’s it. So go easy on me if you reply ![]()
I have one menu I want to stay locked on my main work monitor and another I want to float around depending on the app I’m using. And I can move and resize it and it remembers the position if I use a keyboard shortcut to close it. The complex part is I use a work setup and a home setup and I’d like it to work on boat. But at work the main work window is an external monitor to my MacBook Pro, and the home setup uses a different laptop as the main work monitor and a second display is the secondary.
Thanks
A comment: I keep finding all these actions but I don't can't find tutorials online on what their use is and how to get them up and running, nothing on online documentation as it doesn't go too deep. Can someone suggest tutorial videos or websites that breaks down what some of these pro-Actions do? I can picture in my head @Andreas_Hegenberg creating interesting triggers for use-cases but where is the online documentation for them or some documentation of what they were created for? ↩︎
