Repeat assigned action while pressing problem
Hi. If you define the same keyboard shortcut in 2 different groups, only one of them enabled, then
"Repeat assigned action while pressing" stops working and only executes the action once.
I have made a minimal example of the problem
example.bttpreset (6.0 KB)
Yes, I think I know why.... Anyway, the solution is to delete the deactivated shortcut completely.
Of course you can also delete everything. But sometimes you want to keep macros as examples.
I cannot delete them. They are enabled and disabled dynamically depending on different conditions
Mm, I'm not quite sure anymore, but if I remember correctly, two presets should work. Try activating only one or the other preset depending on the condition.
Hi @Andreas_Hegenberg, just a gentle follow-up—would love your input when you have a moment!
should be resolved in 5.449 alpha (uploading)
It’s fixed now. Thanks again.
