Rename "Named Triggers" for better understanding?
May I suggest renaming “Named Triggers”?
The current name kept me from understanding them – and thus from using them.
Are they Triggers? I don’t think so. In fact, they can’t do anything as is, and even when used they must be attached to an Action and that Action must itself be attached to a Trigger.
A BetterTouchTool “Trigger” is, to me, a system input that results in execution. Since my use of BetterTouchTool is about 95% through Floating Menus, I further think of Triggers as visual objects, but even when not represented as objects shown on a palette they are something the user does. Named Triggers do not trigger and have no configurable qualities other then their name. You don't "do" them. They don't trigger.
They are Action Sequences. Action Sequences saved by name for use with any Trigger you want.
They are an empowering tool once you understand that. I did not, for too long, because of how they are named. (I assumed if I named a Trigger I could then put that Named Trigger on other Floating Menus.)
Andreas covers this simply in the BetterTouchTool Documentation:
  • “Named triggers are basically pointers to one or multiple actions. Named triggers do have a name, but otherwise no configuration.”
This is expanded in the Documentation. I suggest including something along these lines: :
  • Named Action Sequences are pointers to saved Action Sequences. They have a name but no additional configuration. Use them whenever you have an Action or Action Sequence that you intend to attach to multiple Triggers. Use the Action “Trigger Named Action Sequence” to bind the Named Action Sequence to a Trigger. Any changes to a Named Action Sequence are immediately applied to all Triggers that use it.
Please LMK if I have misconstrued this. It won't be the first time. —Kirby.
I agree that it’s quite confusing, because even though Named Triggers are configured in the same way as other triggers, once their function is called by some trigger, they effectively behave like actions.
Maybe a more suitable name would be Named Actions? But then wouldn’t it be confusing that they are still configured in the triggers column? And if a neutral name like Alias were used, would users even understand what it’s supposed to do? This is probably a battle that can’t really be won. :slightly_smiling_face:
But I don’t even know why I’m commenting on this in the first place. I’m not a native speaker (English is my second language) and these kinds of nuances should probably be handled by someone who understands them better.
