I use BTT with the default MacOS control strip and there is a cross on the left of the touchbar that reduces the amount of usuable space by quite a lot. Is there a way for this to be removed or moved somewhere else whilst using the control strip? Would make my setup 100%
unfortunately macOS enforces the x if the control strip is visible. You could disable the control strip and reimplement the functions you need in BTT.
I just find the BTT volume/brightness functions aren't as slick as the control strip in MacOS. Any chance of a BTT control strip in the future?
i recommend two and three finger swipe gestures for that, they are awesome
