I want to replace karabiner-elements completely by BTT.
In karabiner I have swapped my Modifier Keys:
CMD --> CTRL
CTRL --> CMD
UseCase:
- I use a external Keyboard with macOS and Windows
- I want to have the same shortcuts
- Example:
- The Copy-Shortcut in Windows is CTRL+C
- The Copy-Shortcut in macOS is CMD+C
- By swapping CTRL and CMD in macOS, I still can use the same muscle-memory like on windows.
- Also shortcuts defined on my Keyboard (I have dedicated keys for Cut, Copy & Paste) work like intended on both platforms
In karabiner this is fairly easy to setup:
In BTT it's stated that the Key Sequences Feature should be used. I tried to set it up like this (see screenshot) but this led to a endless queue triggering itself.
I would be thankful for any hints on how to achieve this. Note that this needs to operate at the lowest level. I want that BTT afterwards recognizes my CTRL-Key als CMD and vise versa. AND it should only work for the external keyboard - not for the built-in.
Maybe an unsolvable problem - idk.
Best regards,
Volker
