Many times a day BTT crashes.
- Type of Mac: macbook air m1 2020
- macOS version: 13.3.1 (this also reproduced on previous versions)
- BetterTouchTool version: 4.062
I have two user accounts, both of them with BTT installed, same configurations synced using iCloud. This reproduces on both of them.
Translated Report (Full Report Below)
Process: BetterTouchTool [97698]
Path: /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
Identifier: com.hegenberg.BetterTouchTool
Version: 4.062 (2278)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-04-20 21:29:51.6473 -0300
OS Version: macOS 13.3.1 (22E261)
Report Version: 12
Anonymous UUID: 6F710A69-9266-34AD-BBE2-3051800EC9DB
Sleep/Wake UUID: FA2FE7FA-A54F-4EA3-A75C-5DFC2B874A50
Time Awake Since Boot: 150000 seconds
Time Since Wake: 863 seconds
System Integrity Protection: enabled
Crashed Thread: 4 Dispatch queue: com.apple.root.background-qos
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [97698]
VM Region Info: 0 is not in any region. Bytes before following region: 4299489280
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 100450000-100f0c000 [ 10.7M] r-x/r-x SM=COW ...tterTouchTool
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x19f9f7f14 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x19fa0a240 mach_msg2_internal + 80
2 libsystem_kernel.dylib 0x19fa00b78 mach_msg_overwrite + 604
3 libsystem_kernel.dylib 0x19f9f8290 mach_msg + 24
4 CoreFoundation 0x19fb168b8 __CFRunLoopServiceMachPort + 160
5 CoreFoundation 0x19fb15198 __CFRunLoopRun + 1208
6 CoreFoundation 0x19fb1458c CFRunLoopRunSpecific + 612
7 HIToolbox 0x1a9349df4 RunCurrentEventLoopInMode + 292
8 HIToolbox 0x1a9349c30 ReceiveNextEventCommon + 648
9 HIToolbox 0x1a9349988 _BlockUntilNextEventMatchingListInModeWithFilter + 76
10 AppKit 0x1a2d33f58 _DPSNextEvent + 636
11 AppKit 0x1a2d330f4 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 716
12 AppKit 0x1a2d27558 -[NSApplication run] + 464
13 AppKit 0x1a2cfe9a8 NSApplicationMain + 880
14 dyld 0x19f6dff28 start + 2236
Thread 1:: com.apple.NSEventThread
7 AppKit 0x1a2e5e508 _NSEventThread + 172
8 libsystem_pthread.dylib 0x19fa37fa8 _pthread_start + 148
9 libsystem_pthread.dylib 0x19fa32da0 thread_start + 8
Thread 2:
0 libsystem_pthread.dylib 0x19fa32d8c start_wqthread + 0
Thread 3:
Thread 4 Crashed:: Dispatch queue: com.apple.root.background-qos
0 ??? 0x0 ???
1 libdispatch.dylib 0x19f886874 _dispatch_call_block_and_release + 32
2 libdispatch.dylib 0x19f888400 _dispatch_client_callout + 20
3 libdispatch.dylib 0x19f899fb8 _dispatch_root_queue_drain + 684
4 libdispatch.dylib 0x19f89a6c0 _dispatch_worker_thread2 + 164
5 libsystem_pthread.dylib 0x19fa34038 _pthread_wqthread + 228
6 libsystem_pthread.dylib 0x19fa32d94 start_wqthread + 8
Thread 5:
Thread 6:
Thread 7:
7 CoreFoundation 0x19fb995c0 CFRunLoopRun + 64
8 MultitouchSupport 0x1ad6e13dc mt_ThreadedMTEntry + 72
9 libsystem_pthread.dylib 0x19fa37fa8 _pthread_start + 148
10 libsystem_pthread.dylib 0x19fa32da0 thread_start + 8
Thread 4 crashed with ARM Thread State (64-bit):
x0: 0x000060000266b390 x1: 0x0000000000000001 x2: 0x00000001011522f8 x3: 0x0000000000000002
x4: 0x0000000000064002 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x0000000000000000
x8: 0x0000000000000000 x9: 0x00000001f072d961 x10: 0x00000001f4a73bb9 x11: 0x000000000000003f
x12: 0x0000000000000021 x13: 0x000000010680c9e0 x14: 0x0100000102552add x15: 0x0000000102552ad8
x16: 0x0000000102552ad8 x17: 0x535680010252560c x18: 0x0000000000000000 x19: 0x0000000100f17168
x20: 0x0000600000c93960 x21: 0x00006000028da760 x22: 0x0000000000000001 x23: 0x000000000000000f
x24: 0x0000000101199000 x25: 0x0000000000000000 x26: 0x0000000000000114 x27: 0x0000000000000000
x28: 0x000000016fcf30e0 fp: 0x000000016fcf2ec0 lr: 0x00000001008300e8
sp: 0x000000016fcf2d60 pc: 0x0000000000000000 cpsr: 0x60001000
far: 0x0000000000000000 esr: 0x82000006 (Instruction Abort) Translation fault
Binary Images:
0x100450000 - 0x100f0bfff com.hegenberg.BetterTouchTool (4.062) <71fd10ee-28ad-3bd6-a8d1-0f8f8f5cdd06> /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
0x10226c000 - 0x1022bbfff com.mixedinkey.MIKMIDI (1.5) <16ddf028-19de-3847-bbd4-8c164b405d1f> /Applications/BetterTouchTool.app/Contents/Frameworks/MIKMIDI.framework/Versions/A/MIKMIDI
0x10216c000 - 0x102177fff net.wafflesoftware.ShortcutRecorder.framework.Leopard (*) <1f28ebb9-986a-3e5a-b15c-01183c53a265> /Applications/BetterTouchTool.app/Contents/Frameworks/ShortcutRecorder.framework/Versions/A/ShortcutRecorder
0x102190000 - 0x1021e7fff org.sparkle-project.Sparkle (2.2.1) <998f01d4-1e73-3cec-a0c6-5a49be01dbf5> /Applications/BetterTouchTool.app/Contents/Frameworks/Sparkle.framework/Versions/B/Sparkle
0x1024c0000 - 0x10253ffff com.mentalfaculty.ensembles (2.6) <b2228155-dcf8-36c0-8089-894de12517f1> /Applications/BetterTouchTool.app/Contents/Frameworks/Ensembles.framework/Versions/A/Ensembles
0x102150000 - 0x102153fff com.hegenberg.BTTPluginSupport (1.0) <8544739d-8d4d-319f-bd3f-e505148b2242> /Applications/BetterTouchTool.app/Contents/Frameworks/BTTPluginSupport.framework/Versions/A/BTTPluginSupport
0x102120000 - 0x102123fff com.potionfactory.LetsMove (1.25) <4cccd167-7048-39ff-a5c4-594f5fa5e57a> /Applications/BetterTouchTool.app/Contents/Frameworks/LetsMove.framework/Versions/A/LetsMove
0x104ce4000 - 0x104ceffff libobjc-trampolines.dylib (*) <80f14f3d-d099-3693-a8e0-eb9a526b1790> /usr/lib/libobjc-trampolines.dylib
0x1066f0000 - 0x106707fff com.apple.iokit.IOHIDLib (2.0.0) <3f1e2f79-4c68-30b9-92ba-2db9304018d3> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
0x105e5c000 - 0x105e63fff com.apple.CloudDocsFileProvider (1.0) <26e33c5a-f76f-3570-8782-d0dc2d61ff00> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x105e74000 - 0x105e7bfff com.apple.FileProviderOverride (855.100.378) <782f062d-b9d5-3e62-9ce7-b68d197712a2> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x105f14000 - 0x105f33fff com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (13.3) <99856966-e77f-3294-a16a-e59a7e494572> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x105ec8000 - 0x105ee7fff com.apple.security.csparser (3.0) <862735d9-d84d-31b0-bfa8-d75e2271af1a> /System/Library/Frameworks/Security.framework/Versions/A/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x19f9f7000 - 0x19fa30fe7 libsystem_kernel.dylib (*) <7acbd9bc-d056-310e-858d-81b116cf6d28> /usr/lib/system/libsystem_kernel.dylib
0x19fa97000 - 0x19ff70fff com.apple.CoreFoundation (6.9) <b4fdaece-9727-3969-b014-27f7f24c8e01> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1a9319000 - 0x1a964cfff com.apple.HIToolbox (2.1.1) <5f34bbf5-653a-31a5-b4b3-0a02c91ab488> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x1a2cfb000 - 0x1a3c09fff com.apple.AppKit (6.9) <cc3e5215-4cd7-364c-8750-6eb7002720ce> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x19f6da000 - 0x19f76853b dyld (*) <ac277a36-1808-327a-8761-cca585421212> /usr/lib/dyld
0x19fa31000 - 0x19fa3dfff libsystem_pthread.dylib (*) <b401cfb3-8dfe-32db-92b3-ba8af0f8ca6e> /usr/lib/system/libsystem_pthread.dylib
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x19f884000 - 0x19f8cbfff libdispatch.dylib (*) <8e87dc0e-a570-3933-b37d-5e05ad516206> /usr/lib/system/libdispatch.dylib
0x1ad6dc000 - 0x1ad718fff com.apple.MultitouchSupport.framework (6440.7) <7a29bcca-187e-3018-a50d-f3fa210be44e> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.4G resident=0K(0%) swapped_out_or_unallocated=1.4G(100%)
Writable regions: Total=5.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=5.8G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 1
Activity Tracing 256K 1
CG image 288K 10
ColorSync 576K 26
CoreAnimation 1552K 65
CoreData 176K 2
CoreData Object IDs 4112K 2
CoreGraphics 160K 10
CoreUI image data 2080K 17
Foundation 16K 1
Kernel Alloc Once 32K 1
MALLOC 283.5M 57
MALLOC guard page 288K 15
MALLOC_MEDIUM (reserved) 960.0M 8 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
SQLite page cache 1664K 13
STACK GUARD 56.1M 8
Stack 12.0M 16
VM_ALLOCATE 128.1M 5
VM_ALLOCATE (reserved) 3.9G 1 reserved VM address space (unallocated)
WebKit Malloc 192.1M 4
__AUTH 2132K 395
__AUTH_CONST 30.2M 633
__CTF 824 1
__DATA 15.3M 633
__DATA_CONST 30.9M 649
__DATA_DIRTY 2093K 244
__FONT_DATA 2352 1
__INFO_FILTER 8 1
__LINKEDIT 816.7M 14
__OBJC_RO 66.2M 1
__OBJC_RW 2011K 1
__TEXT 650.4M 670
dyld private memory 272K 2
libnetwork 128K 8
mapped file 174.5M 39
shared memory 896K 16
TOTAL 7.6G 3572
TOTAL, minus reserved VM space 2.4G 3572
Full Report
{"app_name":"BetterTouchTool","timestamp":"2023-04-20 21:30:00.00 -0300","app_version":"4.062","slice_uuid":"71fd10ee-28ad-3bd6-a8d1-0f8f8f5cdd06","build_version":"2278","platform":1,"bundleID":"com.hegenberg.BetterTouchTool","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.3.1 (22E261)","roots_installed":0,"name":"BetterTouchTool","incident_id":"DB8944BB-3789-4E48-AF2A-BD1738CB694A"}
"uptime" : 150000,
"procRole" : "Default",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookAir10,1",
"coalitionID" : 1751,
"osVersion" : {
"train" : "macOS 13.3.1",
"build" : "22E261",
"releaseType" : "User"
"captureTime" : "2023-04-20 21:29:51.6473 -0300",
"incident" : "DB8944BB-3789-4E48-AF2A-BD1738CB694A",
"pid" : 97698,
"translated" : false,
"cpuType" : "ARM-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2023-04-20 21:12:49.1461 -0300",
"procStartAbsTime" : 3651996397136,
"procExitAbsTime" : 3676101512197,
"procName" : "BetterTouchTool",
"procPath" : "\/Applications\/BetterTouchTool.app\/Contents\/MacOS\/BetterTouchTool",
"bundleInfo" : {"CFBundleShortVersionString":"4.062","CFBundleVersion":"2278","CFBundleIdentifier":"com.hegenberg.BetterTouchTool"},
"storeInfo" : {"deviceIdentifierForVendor":"F99F7B46-F5CC-5968-B87F-ED54E5CCFCEE","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.hegenberg.BetterTouchTool",
"crashReporterKey" : "6F710A69-9266-34AD-BBE2-3051800EC9DB",
"throttleTimeout" : 2147483647,
"codeSigningID" : "com.hegenberg.BetterTouchTool",
"codeSigningTeamID" : "DAFVSXZ82P",
"codeSigningFlags" : 570512129,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 0,
"wakeTime" : 863,
"sleepWakeUUID" : "FA2FE7FA-A54F-4EA3-A75C-5DFC2B874A50",
"sip" : "enabled",
"vmRegionInfo" : "0 is not in any region. Bytes before following region: 4299489280\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 100450000-100f0c000 [ 10.7M] r-x\/r-x SM=COW ...tterTouchTool",
"exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":97698},
"vmregioninfo" : "0 is not in any region. Bytes before following region: 4299489280\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 100450000-100f0c000 [ 10.7M] r-x\/r-x SM=COW ...tterTouchTool",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 4,
"threads" : [{"id":2818926,"queue":"com.apple.main-thread","frames":[{"imageOffset":3860,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":13},{"imageOffset":78400,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":13},{"imageOffset":39800,"symbol":"mach_msg_overwrite","symbolLocation":604,"imageIndex":13},{"imageOffset":4752,"symbol":"mach_msg","symbolLocation":24,"imageIndex":13},{"imageOffset":522424,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":14},{"imageOffset":516504,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":14},{"imageOffset":513420,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":14},{"imageOffset":200180,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":15},{"imageOffset":199728,"symbol":"ReceiveNextEventCommon","symbolLocation":648,"imageIndex":15},{"imageOffset":199048,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":76,"imageIndex":15},{"imageOffset":233304,"symbol":"_DPSNextEvent","symbolLocation":636,"imageIndex":16},{"imageOffset":229620,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":716,"imageIndex":16},{"imageOffset":181592,"symbol":"-[NSApplication run]","symbolLocation":464,"imageIndex":16},{"imageOffset":14760,"symbol":"NSApplicationMain","symbolLocation":880,"imageIndex":16},{"imageOffset":24360,"symbol":"start","symbolLocation":2236,"imageIndex":17}]},{"id":2819134,"name":"com.apple.NSEventThread","frames":[{"imageOffset":3860,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":13},{"imageOffset":78400,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":13},{"imageOffset":39800,"symbol":"mach_msg_overwrite","symbolLocation":604,"imageIndex":13},{"imageOffset":4752,"symbol":"mach_msg","symbolLocation":24,"imageIndex":13},{"imageOffset":522424,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":14},{"imageOffset":516504,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":14},{"imageOffset":513420,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":14},{"imageOffset":1455368,"symbol":"_NSEventThread","symbolLocation":172,"imageIndex":16},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":18},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":18}]},{"id":2850155,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":18}]},{"id":2852664,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":18}]},{"triggered":true,"id":2854351,"threadState":{"x":[{"value":105553156551568},{"value":1},{"value":4313129720,"symbolLocation":0,"symbol":"OBJC_CLASS_$_AFNetworkReachabilityManager"},{"value":2},{"value":409602},{"value":0},{"value":0},{"value":0},{"value":0},{"value":8329025889,"objc-selector":"isMerging"},{"value":8399567801},{"value":63},{"value":33},{"value":4404070880},{"value":72057598372031197,"symbolLocation":72057594037927941,"symbol":"OBJC_CLASS_$_CDEPersistentStoreEnsemble"},{"value":4334103256,"symbolLocation":0,"symbol":"OBJC_CLASS_$_CDEPersistentStoreEnsemble"},{"value":4334103256,"symbolLocation":0,"symbol":"OBJC_CLASS_$_CDEPersistentStoreEnsemble"},{"value":6005127894967408140,"symbolLocation":6005127890633490432,"symbol":"-[CDEPersistentStoreEnsemble isMerging]"},{"value":0},{"value":4310790504,"symbolLocation":0,"symbol":"__block_literal_global.135"},{"value":105553129453920},{"value":105553159104352},{"value":1},{"value":15},{"value":4313419776,"symbolLocation":0,"symbol":"leaveGapAboveDock"},{"value":0},{"value":276},{"value":0},{"value":6170816736}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4303552744},"cpsr":{"value":1610616832},"fp":{"value":6170816192},"sp":{"value":6170815840},"esr":{"value":2181038086,"description":"(Instruction Abort) Translation fault"},"pc":{"value":0},"far":{"value":0}},"queue":"com.apple.root.background-qos","frames":[{"imageOffset":0,"imageIndex":19},{"imageOffset":10356,"symbol":"_dispatch_call_block_and_release","symbolLocation":32,"imageIndex":20},{"imageOffset":17408,"symbol":"_dispatch_client_callout","symbolLocation":20,"imageIndex":20},{"imageOffset":90040,"symbol":"_dispatch_root_queue_drain","symbolLocation":684,"imageIndex":20},{"imageOffset":91840,"symbol":"_dispatch_worker_thread2","symbolLocation":164,"imageIndex":20},{"imageOffset":12344,"symbol":"_pthread_wqthread","symbolLocation":228,"imageIndex":18},{"imageOffset":7572,"symbol":"start_wqthread","symbolLocation":8,"imageIndex":18}]},{"id":2855976,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":18}]},{"id":2856096,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":18}]},{"id":2856101,"frames":[{"imageOffset":3860,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":13},{"imageOffset":78400,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":13},{"imageOffset":39800,"symbol":"mach_msg_overwrite","symbolLocation":604,"imageIndex":13},{"imageOffset":4752,"symbol":"mach_msg","symbolLocation":24,"imageIndex":13},{"imageOffset":522424,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":14},{"imageOffset":516504,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":14},{"imageOffset":513420,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":14},{"imageOffset":1058240,"symbol":"CFRunLoopRun","symbolLocation":64,"imageIndex":14},{"imageOffset":21468,"symbol":"mt_ThreadedMTEntry","symbolLocation":72,"imageIndex":21},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":18},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":18}]}],
"usedImages" : [
"source" : "P",
"arch" : "arm64",
"base" : 4299489280,
"CFBundleShortVersionString" : "4.062",
"CFBundleIdentifier" : "com.hegenberg.BetterTouchTool",
"size" : 11255808,
"uuid" : "71fd10ee-28ad-3bd6-a8d1-0f8f8f5cdd06",
"path" : "\/Applications\/BetterTouchTool.app\/Contents\/MacOS\/BetterTouchTool",
"name" : "BetterTouchTool",
"CFBundleVersion" : "2278"
"source" : "P",
"arch" : "arm64",
"base" : 4331061248,
"CFBundleShortVersionString" : "1.5",
"CFBundleIdentifier" : "com.mixedinkey.MIKMIDI",
"size" : 327680,
"uuid" : "16ddf028-19de-3847-bbd4-8c164b405d1f",
"path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/MIKMIDI.framework\/Versions\/A\/MIKMIDI",
"name" : "MIKMIDI",
"CFBundleVersion" : "877"
"source" : "P",
"arch" : "arm64",
"base" : 4330012672,
"CFBundleIdentifier" : "net.wafflesoftware.ShortcutRecorder.framework.Leopard",
"size" : 49152,
"uuid" : "1f28ebb9-986a-3e5a-b15c-01183c53a265",
"path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/ShortcutRecorder.framework\/Versions\/A\/ShortcutRecorder",
"name" : "ShortcutRecorder",
"CFBundleVersion" : "1.0"
"source" : "P",
"arch" : "arm64",
"base" : 4330160128,
"CFBundleShortVersionString" : "2.2.1",
"CFBundleIdentifier" : "org.sparkle-project.Sparkle",
"size" : 360448,
"uuid" : "998f01d4-1e73-3cec-a0c6-5a49be01dbf5",
"path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/Sparkle.framework\/Versions\/B\/Sparkle",
"name" : "Sparkle",
"CFBundleVersion" : "2017"
"source" : "P",
"arch" : "arm64",
"base" : 4333502464,
"CFBundleShortVersionString" : "2.6",
"CFBundleIdentifier" : "com.mentalfaculty.ensembles",
"size" : 524288,
"uuid" : "b2228155-dcf8-36c0-8089-894de12517f1",
"path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/Ensembles.framework\/Versions\/A\/Ensembles",
"name" : "Ensembles",
"CFBundleVersion" : "1"
"source" : "P",
"arch" : "arm64",
"base" : 4329897984,
"CFBundleShortVersionString" : "1.0",
"CFBundleIdentifier" : "com.hegenberg.BTTPluginSupport",
"size" : 16384,
"uuid" : "8544739d-8d4d-319f-bd3f-e505148b2242",
"path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/BTTPluginSupport.framework\/Versions\/A\/BTTPluginSupport",
"name" : "BTTPluginSupport",
"source" : "P",
"arch" : "arm64",
"base" : 4329701376,
"CFBundleShortVersionString" : "1.25",
"CFBundleIdentifier" : "com.potionfactory.LetsMove",
"size" : 16384,
"uuid" : "4cccd167-7048-39ff-a5c4-594f5fa5e57a",
"path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/LetsMove.framework\/Versions\/A\/LetsMove",
"name" : "LetsMove",
"CFBundleVersion" : "125"
"source" : "P",
"arch" : "arm64e",
"base" : 4375592960,
"size" : 49152,
"uuid" : "80f14f3d-d099-3693-a8e0-eb9a526b1790",
"path" : "\/usr\/lib\/libobjc-trampolines.dylib",
"name" : "libobjc-trampolines.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 4402905088,
"CFBundleShortVersionString" : "2.0.0",
"CFBundleIdentifier" : "com.apple.iokit.IOHIDLib",
"size" : 98304,
"uuid" : "3f1e2f79-4c68-30b9-92ba-2db9304018d3",
"path" : "\/System\/Library\/Extensions\/IOHIDFamily.kext\/Contents\/PlugIns\/IOHIDLib.plugin\/Contents\/MacOS\/IOHIDLib",
"name" : "IOHIDLib",
"CFBundleVersion" : "2.0.0"
"source" : "P",
"arch" : "arm64e",
"base" : 4393910272,
"CFBundleIdentifier" : "com.apple.CloudDocsFileProvider",
"size" : 32768,
"uuid" : "26e33c5a-f76f-3570-8782-d0dc2d61ff00",
"path" : "\/System\/Library\/Frameworks\/FileProvider.framework\/OverrideBundles\/CloudDocsFileProvider.bundle\/Contents\/MacOS\/CloudDocsFileProvider",
"name" : "CloudDocsFileProvider",
"CFBundleVersion" : "1553.100.384"
"source" : "P",
"arch" : "arm64e",
"base" : 4394008576,
"CFBundleShortVersionString" : "855.100.378",
"CFBundleIdentifier" : "com.apple.FileProviderOverride",
"size" : 32768,
"uuid" : "782f062d-b9d5-3e62-9ce7-b68d197712a2",
"path" : "\/System\/Library\/Frameworks\/FileProvider.framework\/OverrideBundles\/FileProviderOverride.bundle\/Contents\/MacOS\/FileProviderOverride",
"name" : "FileProviderOverride",
"CFBundleVersion" : "855.100.378"
"source" : "P",
"arch" : "arm64e",
"base" : 4394663936,
"CFBundleShortVersionString" : "13.3",
"CFBundleIdentifier" : "com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride",
"size" : 131072,
"uuid" : "99856966-e77f-3294-a16a-e59a7e494572",
"path" : "\/System\/Library\/Frameworks\/FileProvider.framework\/OverrideBundles\/FinderSyncCollaborationFileProviderOverride.bundle\/Contents\/MacOS\/FinderSyncCollaborationFileProviderOverride",
"name" : "FinderSyncCollaborationFileProviderOverride",
"CFBundleVersion" : "1563.5.2"
"source" : "P",
"arch" : "arm64e",
"base" : 4394352640,
"CFBundleShortVersionString" : "3.0",
"CFBundleIdentifier" : "com.apple.security.csparser",
"size" : 131072,
"uuid" : "862735d9-d84d-31b0-bfa8-d75e2271af1a",
"path" : "\/System\/Library\/Frameworks\/Security.framework\/Versions\/A\/PlugIns\/csparser.bundle\/Contents\/MacOS\/csparser",
"name" : "csparser",
"CFBundleVersion" : "60420.101.4"
"source" : "P",
"arch" : "arm64e",
"base" : 6972993536,
"size" : 237544,
"uuid" : "7acbd9bc-d056-310e-858d-81b116cf6d28",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6973648896,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 5087232,
"uuid" : "b4fdaece-9727-3969-b014-27f7f24c8e01",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "1971"
"source" : "P",
"arch" : "arm64e",
"base" : 7133564928,
"CFBundleShortVersionString" : "2.1.1",
"CFBundleIdentifier" : "com.apple.HIToolbox",
"size" : 3358720,
"uuid" : "5f34bbf5-653a-31a5-b4b3-0a02c91ab488",
"path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
"name" : "HIToolbox"
"source" : "P",
"arch" : "arm64e",
"base" : 7026487296,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 15790080,
"uuid" : "cc3e5215-4cd7-364c-8750-6eb7002720ce",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2299.50.120"
"source" : "P",
"arch" : "arm64e",
"base" : 6969729024,
"size" : 582972,
"uuid" : "ac277a36-1808-327a-8761-cca585421212",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"source" : "P",
"arch" : "arm64e",
"base" : 6973231104,
"size" : 53248,
"uuid" : "b401cfb3-8dfe-32db-92b3-ba8af0f8ca6e",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "arm64e",
"base" : 6971473920,
"size" : 294912,
"uuid" : "8e87dc0e-a570-3933-b37d-5e05ad516206",
"path" : "\/usr\/lib\/system\/libdispatch.dylib",
"name" : "libdispatch.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 7204618240,
"CFBundleShortVersionString" : "6440.7",
"CFBundleIdentifier" : "com.apple.MultitouchSupport.framework",
"size" : 249856,
"uuid" : "7a29bcca-187e-3018-a50d-f3fa210be44e",
"path" : "\/System\/Library\/PrivateFrameworks\/MultitouchSupport.framework\/Versions\/A\/MultitouchSupport",
"name" : "MultitouchSupport",
"CFBundleVersion" : "6440.7"
"sharedCache" : {
"base" : 6969065472,
"size" : 3539533824,
"uuid" : "ebddd61c-5dcf-399c-a88b-759edf197103"
"vmSummary" : "ReadOnly portion of Libraries: Total=1.4G resident=0K(0%) swapped_out_or_unallocated=1.4G(100%)\nWritable regions: Total=5.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=5.8G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 128K 1 \nActivity Tracing 256K 1 \nCG image 288K 10 \nColorSync 576K 26 \nCoreAnimation 1552K 65 \nCoreData 176K 2 \nCoreData Object IDs 4112K 2 \nCoreGraphics 160K 10 \nCoreUI image data 2080K 17 \nFoundation 16K 1 \nKernel Alloc Once 32K 1 \nMALLOC 283.5M 57 \nMALLOC guard page 288K 15 \nMALLOC_MEDIUM (reserved) 960.0M 8 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nSQLite page cache 1664K 13 \nSTACK GUARD 56.1M 8 \nStack 12.0M 16 \nVM_ALLOCATE 128.1M 5 \nVM_ALLOCATE (reserved) 3.9G 1 reserved VM address space (unallocated)\nWebKit Malloc 192.1M 4 \n__AUTH 2132K 395 \n__AUTH_CONST 30.2M 633 \n__CTF 824 1 \n__DATA 15.3M 633 \n__DATA_CONST 30.9M 649 \n__DATA_DIRTY 2093K 244 \n__FONT_DATA 2352 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 816.7M 14 \n__OBJC_RO 66.2M 1 \n__OBJC_RW 2011K 1 \n__TEXT 650.4M 670 \ndyld private memory 272K 2 \nlibnetwork 128K 8 \nmapped file 174.5M 39 \nshared memory 896K 16 \n=========== ======= ======= \nTOTAL 7.6G 3572 \nTOTAL, minus reserved VM space 2.4G 3572 \n",
"legacyInfo" : {
"threadTriggered" : {
"queue" : "com.apple.root.background-qos"
"logWritingSignature" : "4696a86f7dfe3e194ced68ef45cba30998225335",
"trialInfo" : {
"rollouts" : [
"rolloutId" : "62c73fd17cce0d1b0bcb8a02",
"factorPackIds" : {
"deploymentId" : 240000061
"rolloutId" : "639124e81d92412bfb4880b3",
"factorPackIds" : {
"deploymentId" : 240000004
"experiments" : [
"treatmentId" : "c28e4ee6-1b08-4f90-8e05-2809e78310a3",
"experimentId" : "6317d2003d24842ff850182a",
"deploymentId" : 400000005
