Recommendations for automation using Stream Deck Clone
Greetings!
I recently got an "AJAZZ AKP03E". It seems to be a white labeled MiraBox stream deck clone "MBox293N3".
If it's somehow possible to use BTT's StreamDeck integration with it, I'd love to figure out how. But I assume I'll have to manually integrate any automations. Looking for tips on the easiest way to achieve this.
Am I correct in thinking assigning long ass hotkeys to the actions I wanna activate is the best/only way to do this?
The device's software has basic functionality, but nothing crazy...
Some things I'd like to be able to to do are:
Window management (set preset layouts with multiple apps)
App control (EG: open Spotify & play a certain playlist)
The controller has an IFTTT integration, but I'd need a IFTTT pro account if I wanted to use it, so ideally I can manage things for free.
Home Assistant integration (I'm new in the HA realm too, but if anyone's got any tips there too, happy to hear em!)
Sorry, BTT's Stream Deck support won't work with this.
