Hallo,
It would be nice if the new "Recently used" entries could also be sorted without the grouping... (maybe that could be configured in the settings)
I have a lot of entries and somehow the list is scrolled to the bottom, the list should always focus/scroll to the first entry when opening (or to the first entry in the group when grouping is active).
A "Clear Recently used list" could help as well ...
No, I see only those 10 trackpad ones, same as you , those 10 are probably 10 in the first section, not 10 "recently used ones" across all sections...I would assume...
Actually I think the behavior is better after deleting some code
In 4.453 the grouping is broken up and the display limits should work. (uploading now)
Selection 1 still only shows the last trackpad gesture, but no other trigger category. The other selections show ... I don't know exactly what. But not what they are supposed to show. At least that's how it is for me.
we getting closer...
over here happens this...
when I select 10 I get 10 items spread over only 3 groups, but when using 30 I see them (max 30) in 10 groups (some groups are now double),
so I assume when selecting 10 I would get at least 1 in each of my groups ?
there are no more groups, the headers now just signify the type of trigger (if multiple same type triggers have been executed in sequence, it will only show the type header once)
