@Andreas_Hegenberg OpenAI's Structured Output doesn't support all keywords in JSON Schema which is annoying, but I was still able to create a JSON Schema based on Draft 2020-12 that works quite well when tested with gpt-4o-2024-08-06.
What do you think?
Example Output
User Query:
middle click with shift, fn, control and left command.
Validated JSON:
"BTTPredefinedActionType": 119,
"BTTCustomClickConfig": {
"clickType": "010",
"modifierBitmask": {
"Control": "Left",
"Option": "None",
"Command": "Left",
"Shift": "Either Right or Left",
"Function": "Function"
"BTTCustomClickUpDownConfig": "0"
BTT JSON:
"BTTCustomClickConfig": "0108519689",
The JSON Schema
"$schema": "https://json-schema.org/draft/2020-12/schema",
"title": "Create_Customizable_Click_Action_In_BetterTouchTool",
"description": "Defines the schema for creating a customizable click action in BetterTouchTool.",
"type": "object",
"properties": {
"BTTPredefinedActionType": {
"type": "integer",
"description": "The predefined action type for a customizable mouse click in BetterTouchTool. Must always be 119.",
"const": 119
"type": "object",
"description": "Specifies the click type and optional modifier keys.",
"properties": {
"clickType": {
"type": "string",
"description": "Defines the type of mouse click with semantic labels for each valid value.",
"anyOf": [
"const": "100",
"description": "Left click"
"const": "010",
"description": "Middle click"
"const": "001",
"description": "Right click"
"const": "200",
"description": "Double-click left"
"const": "300",
"description": "Triple-click left"
"const": "-300",
"description": "Click with button 3 (special)"
"const": "500",
"description": "Click with button 4"
"const": "600",
"description": "Click with button 5"
"const": "700",
"description": "Click with button 6"
"const": "800",
"description": "Click with button 7"
"const": "900",
"description": "Click with button 8"
"type": "object",
"description": "Specifies active modifier keys in full detail, including left and right distinctions.",
"properties": {
"Control": {
"type": "string",
"description": "Indicates if the Control key is active. If the user mentions the Control key but doesn't specify which one, it must always be 'Either Right or Left'.",
"anyOf": [
"const": "Either Right or Left Control",
"description": "If the user mentions the Control key but doesn't specify which one."
"const": "Left",
"description": "If the user specifies the left Control key."
"const": "Right",
"description": "If the user specifies the right Control key."
"const": "Both Left and Right",
"description": "If the user specifies both Left and Right Control keys."
"const": "None",
"description": "If the user specifies no Control key."
"Option": {
"type": "string",
"description": "Indicates if the Option key is active. If the user mentions the Option key but doesn't specify which one, it must always be 'Either Right or Left'.",
"anyOf": [
"const": "Either Right or Left",
"description": "If the user mentions the Option key but doesn't specify which one."
"const": "Left",
"description": "If the user specifies the left Option key."
"const": "Right",
"description": "If the user specifies the right Option key."
"description": "If the user specifies both Left and Right Option keys."
"const": "None",
"description": "If the user specifies no Option key."
"Command": {
"type": "string",
"description": "Indicates if the Command key is active. If the user mentions the Command key but doesn't specify which one, it must always be 'Either Right or Left'.",
"anyOf": [
"description": "If the user mentions the Command key but doesn't specify which one."
"const": "Left",
"description": "If the user specifies the left Command key."
"const": "Right",
"description": "If the user specifies the right Command key."
"description": "If the user specifies both Left and Right Command keys."
"const": "None",
"description": "If the user specifies no Command key."
"Shift": {
"type": "string",
"description": "Indicates if the Shift key is active. Cannot distinguish between left and right Shift keys. Must always be 'Either Right or Left Shift' or 'None'.",
"anyOf": [
"description": "If the user mentions the Shift key but doesn't specify which one."
"const": "None",
"description": "If the user specifies no Shift key."
"Function": {
"type": "string",
"description": "Indicates if the Function key is active. There is only one Function key, so it must always be 'Function' or 'None'.",
"anyOf": [
"const": "Function",
"description": "If the user specifies the Function key."
"const": "None",
"description": "If the user specifies no Function key."
"additionalProperties": false,
"required": [
"Control",
"Option",
"Command",
"Shift",
"Function"
"required": ["clickType", "modifierBitmask"],
"BTTCustomClickUpDownConfig": {
"type": "string",
"description": "Specifies the click behavior with semantic labels for each valid value.",
"anyOf": [
"const": "0",
"description": "Perform a complete mouse-down and mouse-up sequence (normal click)."
"const": "1",
"description": "Perform only the mouse-down event (mouse remains pressed)."
"const": "2",
"description": "Perform only the mouse-up event (release the mouse)."
"required": [
"BTTPredefinedActionType",
"BTTCustomClickConfig",
Python script to load the JSON Schema, make an API query to OpenAPI with a user input describing the customizable click Action in BTT, and a conversion from the outputted JSON to the structure that BTT expects.
from openai import OpenAI
import json
from rich import print, print_json, pretty
from rich.traceback import install
from rich.console import Console
# Install rich traceback and pretty print for better debugging and output formatting
install()
pretty.install()
# Initialize a console object for rich output
console = Console()
def print_d(input_dict):
Prints a dictionary in JSON format using rich's print_json function.
Args:
input_dict (dict): The dictionary to be printed.
return print_json(data=input_dict)
# Initialize the OpenAI client
client = OpenAI()
# Path to the JSON schema file for BTT keyboard shortcut actions
btt_keyboard_shortcut_action_json_schema_path = (
"btt_action_schema/241121_19_50_01_btt_customizable_click_action.schema.json"
# Load the JSON schema from the file
with open(btt_keyboard_shortcut_action_json_schema_path, "r") as f:
btt_keyboard_shortcut_action_json_schema = json.load(f)
# Extract schema details
title = btt_keyboard_shortcut_action_json_schema["title"]
description = btt_keyboard_shortcut_action_json_schema["description"]
properties = btt_keyboard_shortcut_action_json_schema["properties"]
required = btt_keyboard_shortcut_action_json_schema["required"]
# Define the OpenAI function definition using the loaded schema
openai_function_def = {
"type": "json_schema",
"json_schema": {
"name": title,
"schema": {
"type": "object",
"properties": properties,
"additionalProperties": False,
"required": required,
"strict": True,
def query(user_message):
Sends a query to the OpenAI API and returns the response content.
Args:
user_message (str): The message to be sent to the AI.
Returns:
str: The content of the AI's response, or None if an error occurs.
try:
response = client.chat.completions.create(
model="gpt-4o-2024-08-06",
messages=[
"role": "system",
"content": "You are a BetterTouchTool AI assistant.",
{"role": "user", "content": user_message},
response_format=openai_function_def,
return response.choices[0].message.content
except Exception as e:
console.print(f"[bold red]Error:[/bold red] {e}")
return None
def generate_btt_json(validated_json):
Converts a validated JSON object into the original JSON format required by BTT,
using the updated schema for `modifierBitmask`.
Args:
validated_json (dict): The validated JSON object to be converted.
Returns:
dict: The JSON object formatted for BTT.
predefined_action = validated_json["BTTPredefinedActionType"]
click_config = validated_json["BTTCustomClickConfig"]
click_type = click_config["clickType"]
up_down_config = validated_json["BTTCustomClickUpDownConfig"]
# Process modifier bitmask
modifier_bitmask = 0
if "modifierBitmask" in click_config:
modifiers = click_config["modifierBitmask"]
# Define bitmask mapping based on updated schema and BTT documentation
bitmask_mapping = {
"Control": {
"Left": 1 << 0,
"Right": 1 << 13,
"Both Left and Right": (1 << 0) | (1 << 13),
"Either Right or Left Control": (1 << 0) | (1 << 13),
"None": 0,
"Option": {
"Left": 1 << 5,
"Right": 1 << 6,
"Both Left and Right": (1 << 5) | (1 << 6),
"Either Right or Left": (1 << 5) | (1 << 6),
"None": 0,
"Command": {
"Left": 1 << 3,
"Right": 1 << 4,
"Both Left and Right": (1 << 3) | (1 << 4),
"Either Right or Left": (1 << 3) | (1 << 4),
"None": 0,
"Shift": {"Either Right or Left": 1 << 17, "None": 0},
"Function": {"Function": 1 << 23, "None": 0},
# Compute the combined bitmask
for key, value in modifiers.items():
modifier_bitmask |= bitmask_mapping[key][value]
# Combine click type and bitmask into a single string
if modifier_bitmask > 0:
btt_click_config = f"{click_type}{modifier_bitmask}"
else:
btt_click_config = click_type
# Build the final BTT JSON
btt_json = {
"BTTPredefinedActionType": predefined_action,
"BTTCustomClickConfig": btt_click_config,
"BTTCustomClickUpDownConfig": up_down_config,
return btt_json
# Example user query
user_query = "middle click with shift, fn, control and left command."
# Send the query to the AI and get the response
content = query(user_query)
# Print the user query
print("User Query:")
print(user_query)
print()
# Convert the response content to a dictionary
validated_json = json.loads(content)
print("Validated JSON:")
# Print the validated JSON
print_d(validated_json)
print()
# Generate the BTT JSON from the validated JSON
btt_json = generate_btt_json(validated_json)
print("BTT JSON:")
# Print the final BTT JSON
print_d(btt_json)
