I'm trying to configure the Razer Naga Pro 2 and I'm using the generic device.
I was able with the analyser the create the JS that identify the button and so create the trigger for each of the 12 buttons. "LP - Button 1" to 12.
I was able after to use the new trigger created like "LP - Button 1" and assigned some action.
Result:
- The trigger is triggered I can see it with the HUD overlay I added but it still use the basic keyboard key from button 1 which is to print 1 and also the action on the trigger in this exemple W.
- when trigger has been triggered once it doenst re trigger if I press again the button 1 of my mouse.
-> result is W1 rather than just W and then the trigger is not triggered anymore till I click a bit everywhere and at some point it seems to reset it and its triggered again
My script
// Enter your input analyzer script here.
// Do not change the function signatures
function analyzeDeviceInput(targetDevice, reportID, reportDataHex) {
let reportBuffer = buffer.Buffer.from(reportDataHex, 'hex');
if (reportID === 6)
if (reportBuffer.readUInt8(3) === 0x1E) {
log('LP - Button 1');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 1');
if (reportBuffer.readUInt8(3) === 0x1F) {
log('LP - Button 2');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 2');
if (reportBuffer.readUInt8(3) === 0x20) {
log('LP - Button 3');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 3');
if (reportBuffer.readUInt8(3) === 0x21) {
log('LP - Button 4');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 4');
if (reportBuffer.readUInt8(3) === 0x22) {
log('LP - Button 5');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 5');
if (reportBuffer.readUInt8(3) === 0x23) {
log('LP - Button 6');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 6');
if (reportBuffer.readUInt8(3) === 0x24) {
log('LP - Button 7');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 7');
if (reportBuffer.readUInt8(3) === 0x25) {
log('LP - Button 8');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 8');
if (reportBuffer.readUInt8(3) === 0x26) {
log('LP - Button 9');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 9');
if (reportBuffer.readUInt8(3) === 0x27) {
log('LP - Button 10');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 10');
if (reportBuffer.readUInt8(3) === 0x2D) {
log('LP - Button 11');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 11');
if (reportBuffer.readUInt8(3) === 0x2E) {
log('LP - Button 12');
bttTriggerDeviceTrigger(targetDevice, 'LP - Button 12');
UPDATE 1 - I added in my script
bttGetNextEvenWithoutChange(targetDevice, reportID)
This allow to capture next even when i click with the mouse.
So really now the issue is that when i click it trigger the initial key of the mouse "1" and also the trigger I create W so always display W1W1W1 instead of WWWW
