Hello, when I set up the hyperkey function of the raycast, I have always been prompted to close the btt software. Does BTT have similar hyperkey functions that cause conflicts? How to turn off this function? Thank you.
I don’t know why they would ask to disable BTT for that, however you can just setup the hyperkey in BTT, which will then also work in raycast:
可以关闭btt的hyperkey功能吗?
It is disabled by default. The raycast message is not related to BTT’s hyperkey feature.
I can set caps lock as hyper key, but I cannot set clicking caps to switch case and long pressing as hyper key. How do you set this up? Thank you.
