When I repeat "TipTap Left/Right with 2 or 3 fingers fix" gesture quickly, the command is not responding.
It seems like there's 0.3 - 0.4 seconds delay required for repeated gesture command.
Is there setting option to adjust/disable the delay?
I checked BTT Preferences > Advanced > Trackpad > TipTaps.
But I couldn't find the option to adjust the delay there.
On the other hand, repeating "TipTap Left/Right with 1finger Fix" responds quickly without delay.
So I'm using these gestures to quickly move between tabs on Safari.
But sometimes TipTap with 1 finger can be mistakenly recognized as a normal tap which causes unexpected "open link".
Hopefully I wanna assign "TipTap Left/Right with 2 fingers fix" to switch active tab quickly if there's an available setting option.
