Question About Mouse Gesture Configuration with MX Master 3S and BetterTouchTool
Hi Guys,
I have a quick question. I've been using my MX Master 3S together with BetterTouchTool for quite some time and have created numerous shortcuts.
Is it possible to configure the mouse so that when I hold down Button 5 and move the mouse upward, the currently active window is maximized?
Thank you very much for your help!
Best regards, Jaki
yes you can use the discrete drag action trigger categories:
Hello Andreas,
Thank you very much for the quick response! :blush: It worked perfectly. :+1:t3:
However, I still have one issue, or rather a question regarding the implementation:
I would like the current window to be maximized when I press Mouse Button 5 and perform an upward swipe. If I hold down Mouse Button 5 and swipe to the left, the window should be snapped to the left half of the screen. Likewise, when I hold down Mouse Button 5 again and swipe to the right, the window should be snapped to the right half of the screen.
In principle, this is already working. The only problem is that when I press Mouse Button 5, a selection menu with the three actions first appears, and I then have to choose between them.
Is there a way to disable this selection menu so that the corresponding action is executed directly based on the swipe direction, allowing the whole process to work seamlessly?
Best regards, Jaki
that happens if you have the button 5 configured multiple times. Instead make sure you only have it once but with multiple actions for different action trigger categories (all assigned to the same button)
No way, that’s awesome! I had no idea you could even do that :open_mouth: Now, it works perfectly :slight_smile:
Thanks so much! :slight_smile:
I have one more question: Would it be possible to add an additional trigger/action so that, while holding Mouse Button 5 and scrolling the mouse wheel downward, the window under the cursor is minimized?
yes, for that one you however need to create a new separate button + scroll trigger, record by clicking the button and scrolling here:
Amazing, it works! THANK YOU SO MUCH! :+1: :star_struck:
