BTT makes a bunch of connections to various servers. As a rule of thumb, I block apps from making connections using Little Snitch, unless I know what the connection is for. Trying to untangle the ones BTT makes, the ones made by a website widget thing within BTT, and the ones I can block and ignore.
statsigapi . net / sentry . io - presumably analytics? I blocked them with no seeming ill effect.
cloudflare . com - could be anything? I presume I pointed BTT at a website and caused this one. Or does BTT connect itself?
folivora . ai - presumably license confirmation or analytics?
intercom . io / intercomcdn . com / auth0 . com - again I presume this is something I triggered via loading a website? Or does BTT itself trigger any of these?
featuregates . org - this seems to be a Google owned domain and I don't think I triggered it but maybe?
Pointless for me to give any thought to, I'm sure, but I like to know anyway. Thanks!
