I own a process called "Barre" but it is not detected by aditional activation group. Nothing happens when I enable 3 Finger swipe down
Macbook Air
Weird this should work fine.
Just in case there is a misunderstanding: The gestures/triggers will only be activated if the process is the front-most one. So if you configure it to match Safari, it will only activate them when Safari is front most.
