Since I installed 316 this morning, I think I have a bug with the "Show Context Menu" icon in the menu bar. After a crash or restart of BTT, I lose the icon, and it is impossible to make it reappear. I deleted and recreated it, but a few minutes later, the same thing happened again. I also have a menu bar item with just an Apple Script, and that one don't disappear.
can you copy & paste the item here?
I don't think there have been any related changes, but I can definitely check!
I can't copy and paste it here; it's too long. Why is there so much "text" when I copy and paste inside BTTIconData?
menubar.json (158.2 KB)
depends on the icon file size, encoded to base64 they can be quite big, I'll checkout the json!
it seems to work ok here. Is it maybe hidden from your menubar because it's too full? (Or did you maybe experiment with BTT's status item management features?)
If it's just hidden you could create a shortcut to move it back into the visible area:
Thank you for the advice; I will do that.
