Preventing accidental triggers for Screen Edge Gestures
Hi Andreas,
First of all, thank you for creating such an incredible tool! I use BetterTouchTool daily and it has completely changed my workflow.
I am currently using the Screen Edge Gestures to trigger specific actions and launch applications. While I love this feature, I frequently run into an issue with accidental triggers when working near the edges of my screen.
Would it be possible to consider adding settings to help prevent these false positives? For instance:
  • Adjustable activation zone / dead zones: Being able to customize the width/thickness of the edge detection area.
  • Trigger delay (Hold duration): Requiring the cursor to stay on the edge for a configurable fraction of a second (e.g., 0.2s) before firing the action.
  • Velocity or threshold checks: Ensuring the gesture requires a deliberate movement rather than a casual mouse pass.
  • Others ?
Thank you for taking the time to read my feedback and for your continuous hard work on the app!
Best regards,
Florent
