I backup and restore my BTT preset from files fairly frequently (I end up re-imaging my machine a fair amount). I have several Keyboard Shortcuts which use the "Prevent recursive triggers" attribute. These don't seem to show up in export files.
If I do the following:
- Check that the checkbox is checked on a given shortcut
- Export the preset to a file
- Create a new, empty preset
- Delete my main preset
- Load the file
- Result: the triggers are restored, but the "Prevent recursive triggers" checkboxes are unchecked.
- Type of Mac:MacBook Pro (13-inch, 2018, Four Thunderbolt 3 Ports)
- macOS version: 10.15.3 (19D76)
- BetterTouchTool version: 3.346 (1554)
