Have a normal Mouse Long press button as a trigger.
There's still a problem with Modifier Keys.
I wanted to remove the modifier key for the current Trigger to change it to Hold setting, but it didn't work.
I had to create an entirely new trigger and delete the first one.
This is a problem Mainly with the Shift Modifier key, It shows deactivated in the UI, but in reality, it's still active and I have to hold Shift to trigger the action. (Also happens with ctrl)
