I just did a clean install of Mojave on my Mac Pro (Late 2013), and after installing BTT, I have tried going to the manage presets and import a preset that I saved a few months back. But even though I locate the .json file via the import window, nothing imports. I only get the default.
Any help would be greatly appreciated.
- Type of Mac:
- macOS version:
