Preferences menu keeps popping up randomly
The BTT preferences panel pops up randomly multiple times throughout the day. I am using the Setapp version.
Macbook Pro
  • Type of Mac: MacBook Pro (13-inch, 2018, Four Thunderbolt 3 Ports)
  • macOS version: 11.6 (20G165)
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
    3.570
Same problem here. Very annoying.
This has been happening for me for a long time. I can't find any pattern, it happens when I'm doing nothing just sitting near the computer, it happens when I'm away and I find the prefs dialog box open when I return, it happens when I'm in the middle of doing things. It happens when I have my external keyboard and mouse plugged in, it happens when I'm just using my bare laptop. It happens day and night. Sometimes it happens soon after it happens before, sometimes it's a day or two in between.
v3.579
Is there any solution to this? I keep facing this issue as well. It seemed to have stopped and then just started happening again yesterday. Happens many times a day!
I found a solution.
Step 1: Uninstall the app
Step 2: Keep the app uninstalled
Step 3: Done!
