Please help me with conditional activation
Hi there,
I'm demoing this super cool app and it seems to offer exactly the functionality I'm looking for, but I'm struggling to get it working how I want it to.
I'm using it with my DAW (Cubase) and I want to have multiple floating menus that are only visible in certain windows and can all be toggled on and off simultaneously.
I've gotten a basic test toolbar to toggle on and off, but I'm struggling with the conditional activation group. My test toolbar should only be visible when I have the Key Editor window open, and I've set up rules accordingly. However, when I close the Key Editor window the toolbar remains visible, though my toggle button ceases to work (which makes sense for the logic I'm using right now). When I switch away from BTT and go back to Cubase, the toolbar is gone (visibility state not persistent).
In short I want to have two different areas of logic set up for my workflow - individual floating menu bars that are only visible in certain windows of the application, and a global toggle key (tilda) to show and hide them. I've love for their visibility state to be persistent so if I have my toolbar visible in the Key Editor, and close the Key Editor, the toolbar is no longer visible in the main window, but if I reopen the Key Editor the toolbar is still visible.
Is it possible to set it up to work like this? If yes, it would be lovely to get some pointers for how to get it working. Thanks!
