Please do not deprecate BTT Remote until Mobile has feature parity
There are too many functions in BTT Remote I use regularly to change to the new “improved” app. The function keys and keyboard access on the touchpad are so convenient, and having the cursor size scale up when the touchpad is used is invaluable.
Please don’t deprecate this app until you have feature parity in BTT Mobile.
BTT Mobile does already have all functionality BTT Remote had. Can you maybe point me at which function keys you are missing?
Both of these trackpads offer more functionality than the trackpad in BTT Mobile.
The concept of BTT Mobile is different, it gives more flexibility but requires to create your own layout to make use of everything. I can post an example floating menu that is kind of equivalent to your screenshots later.
I don't have plans to remove BTT Remote though, it will however also not receive updates anymore.
Ah well, I think adding some options to the default trackpad doesn't hurt.
I just uploaded a new version to Testflight (TestFlight - Apple ) that will have this once it is approved by Apple:
