"Pixel threshold before starting to move or resize" setting
Hi Andreas, I've noticed that over time, my snapped windows "drift" a few pixels. I think this is the normal behavior of Mac, not something to do with your software. I came across the "Pixel threshold before starting to move or resize" setting in the Extras menu of Better Snap Tool, and it sounds like what I'm looking for – essentially, prevent small, unintentional movements to the window position. However, I don't see a noticeable effect to the movement of windows. Is this setting intended to do what I hope it does?
Thanks,
Danny
this just controls when a window should start moving with BTTs window moving functions. I can’t control the standard macos window moving ;-(
Bummer. Thanks for the clarification!
