When I active better touch tool, I found that I cannot use pinch to zoom gesture with Magic Trackpad, yet the pinch too zoom option system preference was checked.
However, when I inactive the better touch tool, the pinch to zoom gesture works.
I have set the rotate gesture as volume knob before but I have delete it after the pinch to zoom failed.
Magic Trackpad
MacBook Trackpad
- Type of Mac: MacBook Pro 13-inch (intel)
- macOS version: macOS 11.4
- BetterTouchTool version: 3.562
