I am not sure if this is caused directly by BetterTouchTool, but I'm reporting in case others have the same experience, in which case it should be fixed.
Problem: When my system is under heavy load (high RAM usage), I would sometimes experience phantom clicks or phantom drag and drop, particularly of windows and tabs in Safari. Also, when I trigger space switching with "ctrl ->" or "ctrl <-", the computer would switch to the new space and then switch right back. These problems seems to go away if I disable BetterTouchTool.
For now, even though I love the product, I'm chosen to stop using it and use another alternative, at least until I feel comfortable knowing what's the cause. These phantom events (clicks, drag and drops, space switching) are kind of dangerous.
Affected input device (e.g. MacBook Trackpad, Magic Mouse/Trackpad, Touch Bar, etc.): Mouse (and keyboard?)
- Type of Mac: MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
- macOS version: 10.15.2
- BetterTouchTool version: 3.262
