Any possiblity that i not trigger the permanet-shift-key randomly? I want this key just trigger by pressing this +special key!
You could swap caps lock with (right) control in macos. That way, nothing happens if you press the key by mistake.
With control + letter and this action you then have the function of the Caps Lock key (Feststelltaste).
Or configure BTT hyperkey.
I dont know.... Yes that would be perfectly fine, but i didnt find such SETTING in Sys-Config-Keybord-Settings????
Do you have a screenshot?
