there is a significant delay while performing undo ( cmd + z = 2 finger tap ) & redo ( shift + cmd + z = 3 finger tap ) action..
note : it is happening only on figma and especially to these two undo & redo action.. rest are working fine
that sounds like a figma bug or setting.
However it’s pretty weird because all BTT does is send the keyboard shortcuts.
If you perform the keyboard shortcuts manually there is no delay?
Or do you have two finger / three finger double tap configured in BTT? If so BTT will wait to see whether the double tap happens before executing the non-double-tap versions.
yes "two finger / three finger double tap configured" these caused the delay
