Pasted Text in Wrong Order
Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool and that you have already tried to restart your system :-). If you encounter a crash, please attach a crash log from the macOS Console.app's "Crash Reports" section.
when I trigger my Paste Text sometimes the text arrives disordered.
  • Apple M1 Max 64GB.
  • macOS version: 26.7.1
  • BetterTouchTool version: 6.875
Can you copy & paste the whole key sequence JSON here? (select the key sequence in BTT, press cmd+c, then cmd+v here)
One thing you need to be careful about: if you type ysa, immediately followed by some other characters without giving it type to insert the text, your continued typing might interfere with the text insertion.
