Paste Text issue
Triggering this action will create the correct string (yyyy-mm-dd) but using the font that the machine has in the "clipboard"...
Let say I have copied a text written in Arial, and now I am writing an e-mail using Helvetica, the BTT will paste the yyyy-mm-dd in Arial.
Before the BTT would have paste a "plain text".
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
Could you check whether this is resolved in 5.190?
Yes! Solved in 5.19.
Thanks and great job :slight_smile:
