I made an action sequence that included multiple "Paste Specific Item" triggers in the sequence. It begins by copying from one app and then switches to another app and begins paste. It originally worked, but now, the trigger "Paste specific Item" trigger pastes everything as the very last sequence, and all together. Example:
App 1:
-tab
-Press: Command-C
-Press: tab
-Press: Command-C (clipboard would now show 2 items).
-SWITCH app
-Press: Command-G
-Type: abcd
-Esc
-Press: tab
-*Paste specific item #2
-Press: tab
-*Paste specific item #1
-Press: tab
(THIS IS THE ERROR: BBT pastes #1 and then pastes #2
I've tried different apps and it used to work. I've tried:
-changing the trigger from typing, format paste, etc.
-resetting comp, BTT.
-updating mac and BTT.
-closing other apps and more.
I've had this trigger sequence work before and I'm thinking I changed some kind of setting. Are you able to assist?
