Hi folks,
ich would like to paste a picture (from my harddisk, not memory/clipboard) on my cursor-position after hitting a trigger-key. I tried this with "insert from clipboard", but when it asked for a certain position of the clipboard list, my picture moves from one to another position, when I paste another things - and then an other thing is inserted.
So I thought of a certain AppleScript, but want to ask here first, if anyone has a solution for this topic...
Looking forward for your ideas, thanks in advance!
kind regards, Sandro
You should be able to drag an image into the "Insert / Type / Paste Custom Text" editor. Just make sure to select "Paste Format" "Rich Text"
thank you very much!!
