I'm composing rudimental drum music in Logic Pro X and am trying to create BTT triggers to insert rudiments (primarily 5, 7, 10 and 15 stroke rolls and paradiddles) - otherwise I have to either build each rudiment from scratch, or find the rudiment and copy/paste it into position.
I used BTT to make keyboard shortcuts exclusive to the Logic Pro X app, with the desired functionality - but instead of pasting the notes associated with the trigger, all of the triggers paste the same rudiment.
I'm using Logic Pro X 10.5.1 and BTT 3.549 (1689) on macOS Mojave 10.14.6.
Any suggestions are greatly appreciated!
