Hello,
I have tried everything I can think of (turning Apple TV off, resetting the remote, and the correct pairing button presses (Menu + Vol up)), but I cannot get my Siri Remote to appear in the new device list on the Mac.
Please help!!
Hello,
Please help!!
which Macbook Air do you own?
MacBook Air M2, 2022
ah I just checked - unfortunately Apple has dropped support for the first generation Siri Remote after macOS 14 ;-(
Only second and third gen still work.
Damn, I have just bought this remote as a replacement.
I have tested with a Gen 2 and it works fine.
Thank you.
Is there a work around for the Gen 1?
Would be really great to get that working again.
i don't think there is a workaround
I have bought a Santechi R1 Remote instead. I am trying to set it up in other apps. But in the Generic Input tool, when I click a button, no input is recorded. Can you help? Can I use it in a different way?
Maybe have a look at the RemoteBuddy app! I don't think you can do it with BTT
