Hello there,
I've search high and low on the internet and scoured the community here to no avail. Back in the day (this is YEARS ago) when I used BTT, I was able to specify gestures that were app specific without activating system gestures.
I currently have 2 finger swipe left/right to swap between desktops in the System Preferences under the Mouse pane. After adding an application to BTT and setting up a new gesture (2 finger swipe left), it triggers the keyboard shortcut in the application, but at the same time engages the swipe between full-screen apps.
Is there a way to ignore the system gestures and have only the application in focus react to the input? I'm sure the solution is in plain sight, I just can't seem to get my head around what I'm looking for or where the option/trigger necessary is located.
I'm sorry if this is an obvious question, and thank you in advance for any help I receive.
//Henrik
