Hello Everyone,
I have a question for you all...
What is the best way to override a trigger from a preset? For example I have been using the AquaTouch preset for a while now, but I do have a master that I keep with some custom triggers...
I want to overwrite some triggers on the AquaTouch from my default one, for example I created the same keyboard shortcut on the default, but when I press it a dialog to choose the trigger shows up....
Ideally I wanted to my preset to have a priority on execution and stop following triggers to be executed...
Is there a way to accomplish this?
