My problem is identical to the one reported here: OS lag. extremely noticeable when click and dragging windows around the desktop
My computer has been choppy, especially when moving windows, for months and I just chalked it up to something I couldn't control. But I closed BTT and it was smooth again!
The solution that poster proposed was this, which did not work for me:
Just figured it out. When mouse is set to:
**Report rate (per second):**
**1,000**
It get laggy.
I've always set it to 1,000 but no issues with BTT in the past. I'll continue with 500 and make sure it runs smooth.
Was using a Razer and now Logitech currently with their driver software.
If I click a title bar, wait a couple of seconds, then drag, it's smooth. But if I just click and drag like normal, I get a stutter. I have an MX Master 2S so I cannot adjust the report rate.
I have also tried resetting BTT to factory settings and removing all presets, and the lag still occurs. It's almost as if BTT is detecting my mouse click and waiting to see if I do something else, if that makes sense.
Any. mouse/trackpad.
Copying link from original poster: https://www.youtube.com/watch?v=j4gh03U29fY
- Type of Mac: 2017 MacBook Pro 15" with Touchbar
- macOS version: 10.14.4
- BetterTouchTool version: 3.099
Possible software conflict?
- Logitech Options software with unifying software (MX Master 2S and K750 Keyboard)
Don't have anything else running that I would see be a problem.
