Order for "Move Window to Next Monitor"
Hi and thanks for this tool, which I use all the time and consider essential. I recently got a portable monitor so now have a three-monitor setup. When I activate “Move Window to Next Monitor”, my understanding is that it should cycle Left → Middle → Right → Left. Instead, it cycles Left → Right → Middle → Left. The monitor proportions are as shown in the image. Is there some way for me to configure the order directly, or alternativley, is this either the expected behaviour or a bug? thank you!
I am also having the same problem with a similar config. Any updates on this?
