I have a keyboard shortcut that opens up a specific search engine with the selected text - it works in QWERTY layout but not in (french) Dvorak layout.
Keyboard
- Type of Mac: Macbook pro
- macOS version: Mojave - latest
- BetterTouchTool version: 3.084
keyboard shortcuts are bound to the physical location of the keys by default. You can check the "auto-adapt to keyboard layout" checkbox, then BTT will try to map it to the correct letters.
Sorry I should have better explained myself : when I press the keyboard shortcut, a browser window is opened as expected with the search engine, but the selected text is not "transmitted" to the URL.
For example :
- I copy the text "abc" manually myself so it gets entered to the clipboard
- I select the text "def" and press the keyboard shortcut
- A browser window will be opened as if I had selected the text "abc" (or with a null string if nothing was previously in the clipboard
So the part of the function in BTT that fails when in another keyboard layout is taking the selected text and copying it into the search engine URL.
I hope it's more clear !
Alex
Have you been able to reproduce the problem?
If you need more info just let me know.
Alex
Yes, will be fixed with next update!
Quick note, both selected text and the clipboard don't seem to yet function?
I highlight (say):
www.npr.org
and run:
https://mediabiasfactcheck.com/?s=%a
which should return:
https://mediabiasfactcheck.com/?s=www.npr.org
However, whether I use highlight text or copied text, from the url itself or text from a web page--BTT seems unmoved. The transferred url in all cases is just:
Am I doing something wrong?
