Note:
When asigning actions to any of the 1 finger taps on my built in trackpad, they almost never trigger. Top middle works about half the time, top left and right basically never work (1% maybe). Corner clicks don't work either. Two and more finger gestures seem to work properly
Built in trackpad
- Type of Mac:
- macOS version:
MacBook Pro 16" 2023 M2 Max
OS 13.5
