Using 1 finger tap mapping to left click. When doing a click on window from Intellij IDEA BTT restarts
MagicMouse
- BTT icon shows as gray after doing a tap
- Type of Mac: MacBook PRO 13" 2016
- macOS version: latest: 10.14.1 Mojave
- BetterTouchTool version: latest: 2.660
1542612770.227548|ASL|[Crashlytics:Crash] Warning: NSApplicationCrashOnExceptions is not set. This will result in poor top-level uncaught exception reporting.|
1542612803.181803|TERMINATE|SHOULDTERMINATE|
1542615686.955269|usage|loading todays usage|
1542615687.021892|ASL|[Crashlytics] Version 3.9.3 (128)|
1542615687.057319|short|init|
1542615687.120754|LIC|idate 2018-01-26 21:23:19 +0000|
1542615687.133762|short|register all hotkeys|
1542615687.142501|short|register disable hotkeys|
1542615687.143374|short|register disable hotkeys|
1542615687.144282|short|register all hotkeys|
1542615687.169566|LAUNCH|DIDLaunch|
1542615687.171475|xw|trial has ended|
1542615687.203827|xw|disable|
1542615687.211135|short|register disable hotkeys|
1542615688.249580|short|register disable hotkeys|
1542615688.252197|short|register all hotkeys|
1542615689.053620|ASL|[Crashlytics:Crash] Warning: NSApplicationCrashOnExceptions is not set. This will result in poor top-level uncaught exception reporting.|
1542615690.857921|webserver|init|
1542615691.365411|lic|in new updater method|
1542615691.860799|ASL|*** WARNING: Method convertPointToBase: in class NSView is deprecated on 10.7 and later. It should not be used in new applications. |
1542615692.002656|ASL|Bonjour Service Published: domain(local.) type(_bttremote._tcp.) name(Radu’s MacBook Pro) port(60446)|
1542615698.087802|ASL|did open|
1542615699.389312|TERMINATE|SHOULDTERMINATE|
