old version Exported Preset help
hello, i have a exported preset from a Mac i had to replace.. i found the document. but it didnt save in a .bttpreset format. the preset is basically keystrokes for a Audio Workstation DAW. Combinations of keystroke’s i didnt want to remember.
Is there a way i can convert this script looking text to be able to import onto my new mac? would hate to have to rebuild this preset again.
i cant upload the file because the file type says its just a document. when i change the extention to “.bttpreset”, btt wont read it for import. was hoping to be able to convert this somehow or something.. if possible
heres the Text the document shows when opened
bookmark88`:ï∂üûl≈AåApplicationsTouchbar App Presets$¥9Œ=P`A≈lûÑôÆ£	file:///Macintosh HDêÇñÁAƒ‚ªn$A9B5FB5D-38CA-43B3-9FDC-20C34ED89108ÅÔÔ/0dnibrdlfÃ˛ˇˇˇ@pê@Ä H ∏ » ¸ ‹ Ï  (0 ∞–∞–$"T
could you send that to andreas@folivora.ai? It doesn't look like BTT's preset format, but could maybe be a database file. How old was the version you exported this from?
//edit: if this is the whole content of the file - this is not the actual file but some sort of link to it
//seems to bd a finder alias: Bookmarks, a type of Alias: their access and use – The Eclectic Light Company
maybe the original file is still somewhere in your backup?
it was from 2021, i cant remeber the version but i sware i just found the old log since i installed the exact old version i made it on and then i had to update when i opened BTT
Unfortunately it is the entire content of the file. i guess that means ill be remaking it. oh well, at least now i can share it to the local form to find for myself again if i ever need it
