When toggle Notch Bar mode, Multiple click application menu no responding, and pointer blink blink ,when toggle hide Notch Bar ,clicking on the menu is normal。
I didn't run this program,Do you think it was caused by a procedural conflict?I just killed all the programs, better touch tool restarted. and it's still the same problem。
Just now I created a new user, the system only runs the better touch tool, the problem is solved。 I don't know which program conflicted.thank you.I also have a question, /Library/Preferences/com.apple.bluetooth.plist This file system does not automatically generate, do you know what's going on?
