I was using "sleep" action by sequence. but now it is not working.
when I create new Sequence, it just recording "shift, control, option, command".
How can I using sequence?
All Keyboard
- Type of Mac: M1 MacBook air
- macOS version: 11.3
- BetterTouchTool version: 3.562
