Not triggering Willow Voice and Wispr Flow
BTT used to trigger and activate Willow Voice and Wispr Flow but for some reason it stopped. Is there anything I can do to figure out why it no longer triggers the shortcuts for these applications?
Can you give some more details? how are they being invoked?
I quickly tried with willow voice. They seem to capture key events at the lowest possible level. Not sure why they would do that.
I added an option in 6.354 (uploading) to send shortcuts at that level to make it work:
