not receiving triggers from input parsing script
Hi.
I’m trying to set up a bluetooth controller (16 buttons, all on/off, no joysticks or anything fancy) as a generic device.
The parsing window does properly register any inputs. However, none can be used as triggers in the main app as the input list seems not to get forwarded. So far, I haven’t done much to the Java code apart from decommenting some lines.
Is this a bug I’m encountering or is there some other action that has to be performed to have the inputs show up in the trigger list?
Regards,
Chris
can you post screenahots of your configuration?
I don’t think there’s much to show. I’ll dump anything I can think of:
Additionally, the parsing history in the popup window is not consistently tracked. Sometimes, inputs get added, sometimes not. Haven’t really noticed a system behind that behavior.
OS:
macOS Tahoe Version 26.0 (25A354)
System Specs:
Modellname: MacBook Pro
Modell-Identifizierung: Mac15,6
Chip: Apple M3 Pro
Gesamtanzahl der Kerne: 11 (5 Leistung und 6 Effizienz)
Speicher: 18 GB
Systemfirmwareversion: 13822.1.2
OS-Ladeprogrammversion: 13822.1.2
Gamepad Specs:
Adresse: E4:17:D8:2E:55:80
Hersteller-ID: 0x2DC8
Produkt-ID: 0x9020
Firmwareversion: 1.0.0
Minor Type: Gamepad
RSSI: -55
Dienste: 0x800020 < HID ACL >
in your last screenshot you need to enter the namesof the triggers you want to allow in “bereitgestellte trigger”
(e.g. button6)
