The Next Events/Reminders Touch Bar widget no longer shows all remaining events for the day. I have three events left, but my notification of no more events is showing. I don't select any calendars, rather I just allow BetterTouchTool to use the Apple Calendar app as its source.
- Type of Mac: MacBook Pro 16,2 (MacBook Pro 16" 2019)
- macOS version: Sonoma 14.0
- BetterTouchTool version: 4.273
is it maybe missing the calendar permissions in system settings-> security & privacy?
Andreas,
That was it. Oddly though, I hadn't changed that at all. The only difference between the day before yesterday and yesterday was the upgrade to macOS Sonoma 14.0. Could macOS have required a new reauthorization of "Full Access" with the upgrade? One other app I use also needs "Full Access" to my calendar, but I didn't have to do anything to keep it running as I had before on Ventura.
upgrading macOS has caused buggy/corrupted permission databases since Apple has added the permissions a few years ago. Not sure whether that will ever be fully resolved (it got much better though). At least they are usually easy to fix
