Hi! relatively new to BTT and Aquatouch preset...and I want to add to my mac the BTT option to enable "Floating" windows. How should I configure that? I dont want to ruin anything :.)
Thanks!!!
Thanks!!!
Hi, I do not use Aquatouch. But I don't think you can ruin anything by adding a button ![]()
If you want to be absolutely sure, just disable the Aquatouch preset and create a new test preset to experiment.
