New Option: When Bluetooth LE Device Has Been Away for More Than X Seconds
I use a BTT automation with the "Bluetooth LE Device Moved Away" trigger to lock my MacBook when my Apple Watch moves out of range.
However, despite setting a relatively large distance threshold, my MacBook occasionally locks even when the Watch is still nearby.
It would be great to have an option like "When Bluetooth LE Device Has Been Away for More Than X Seconds" to prevent brief signal dropouts from mistakenly triggering the lock.
Thanks and best regards,
Robert
I ran into same issue.
For now I have this workaround until this is natively available in the App.
On, Device Moved Away trigger → Execute action sequence after 5 sec → Run Shortcut (lock Mac when away)
On, Device Came close trigger → Cancel Timed Action Sequence
mac_lock_when_away.bttpreset (23.8 KB)
